Just came in from coat #4. The more I do this, the easier it is to put on. I did find out that you don't want to keep that foam brush in the paint that is thinned already. It started to break down and put crap in the paint. I took a soaked mineral spirits rag and wipped the whole door and t-tops off and started coat #4 over again. Wasted 2 buck in paint too!!! heh...
This might be my last coat due to it being black aready before the paint.
The very large areas to cover can sure be a pain. I had to continue working on around the front to keep from getting the stopping and starting lines.
Here is a picture of coat #4
