A possible whacky side effect is that the carrier being drawn into the bondo may in fact work to soften the bondo. And when the paint layer dries, the carrier trapped down in the bondo will not be able to rise and easily evaporate through the skin of the paint. It may cause sort of a blister type effect as the gas evaporating from the bondo and gets trapped under the paint skin.
Argh - didn't think about that.......
Thanks for your input. I think I'll wait a few days before I try and prime the bondo areas or try and do any more coats.
The bondo is mainly a skim coat in the areas where I had to use it, so hopefully that will lessen the potential effect you referred to.
I new it would be easier to cover if I primed it, I just got overanxious since I finally had some time and the weather was co-operating.
After pulling the car outside in the sun I found a whole bunch of minor prep areas that need to be addressed, so I just need to back down and take my time and do it right.
But overall - this is still AWESOME!
Thanks again.
