Is that Brightside or Rustoleum?
This is the Rustoleum you buy at walmart. $7.65 a can. So far, it isn't to hard to put on. I also have a few dust bunnies to work out, but overall, as long as I can get it to harden up, I'll be doing it on a few more toys...
That would have been the absolutely ideal body to have done the Brightside on... since the Vette body is so similar to the fiberglass and gel coat used on boats ( for which Brightside is normally applied to ).
It will be interesting to see how the Rustoleum holds up on the Vette body. All I can recall from my past is that bodywork and painting on Vettes usually required slightly different prepping and painting than regular cars at the Pro paint shops. And usually the pro-paints charge more to do them.... and half of the shops wouldn't even try to do them.
If you do encounter adhesion problems with the Rustoleum/Tremclad... at least you will know that you can safely fall back to the Brightside.
