I have read pretty much the entire thread(s) (ouch) and came up with a question. I know some here have sprayed their paint on with HVLP and used the MS, I am wondering if there is another catalyst that we can use for spraying that thins out the paint, but doesn't retard the drying time as much, like acetone? I have read a few problems spraying it with the MS (runs) so I am thinking something that flashes a little faster would be better to use when spraying? Thanks,
Brew
good question Brew.
I will do a test and see how it comes out using Acetone instead of MS.
