you need to sand down enough so that the rustoleum has someplace to bite into and stick to the old paint. also the goal with sanding is to get the car smooth. once its there you can apply paint, if that means going to metal than so be it, if it means just a light wetsanding then your lucky.
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
