here's a better pic. I still have to wetsand and add couple more coats.
I don't know if it's just the picture or not but that seems awefully "peely". When I did my test, even with a 20% mineral spirits mix I had a lot less peel than that. I'd be concerned that you will have to burn thru several layers to get it smooth if it's as bad as the picture makes it look, No offense, just trying to help. What type of roller are you using?
