I think you're getting way ahead of yourself using 1200 after only 2 coats.
True.
I hope he meant move up a grade after each two coats, and did not mean doing 600, then 800, then 1000, then 1200 and then do another two coats.
Just to be clear - it should be:
2 coats
600
2 coats
800
2 coats
1000
2 coats
1200
yep thats what i meant. after 2 coats, step it up a grade.
well that 5th coat turned out HORRIBLE after it got rained on. it left unwashable water spots on the surface. so i busted out 800g and sanded the hood off.
So basically I just put on another 5th coat, with more bad results
Prepped the surface, laid a the 5th coat and this is where it begins. For some reason, there was a swarm of gnats (small annoying flys) hanging over my trunk. They literally waited till i finished painting to dive bomb the hood. im guessing the smell or the shine must of attracted them. so now i have a wet hood with some bugs on it. oh and I tried to pluck them out, but it was a losing war.
Well here are the pics. NEW 5th coat after sanding original water-spot 5th coat.
loving the reflection, but damn bugs, dog hair and grains of dirt ruin it.
Spring time comming up. pollen coated vehicles are a common site around here.
niiiiice
Ok I did some crappy photo editing in photoshop. Heres a shot of some of the bugs that flew into my paint in the green circle.
same shot, no editing.
Guess im going to have to live with it. Its not like im painting for a show quality finish.
