I'm gonna use the white "Stops Rust" paint. The van is like i said a dull, faded metallic blue.
I think i'll spray the jambs, and around the tight spots first, then start with the roller.
The plan is to get the body as straight as i can, then use the rust-oleum primer (rolled on), wet sand that, and then paint it. I used to work in a body shop as a mechanic, but I did alot of watching and learning from the body men there so I think it should turn out ok. I'm not building a "show van", i just want it to look good as a daily driver.
