I have given up...I have been sanding and polishing this damn thing for two days......here comes the spray gun. Should I use spirits or acetone to thin it?
Don't use acetone unless you have an oxygen respirator pack on. The fumes will kill your brain and your kidneys. It also makes one heck of an explosive mixture when atomized in the air and finds a spark ( yes something as simple as the spark of the rotator brushes in the electric motor of cheap electric spray guns.
There was some discussion earlier in the thread about the right mixture or flow rate to cut your paint with mineral spirits to get a good vaporization of the paint when spraying.
