Okay, how much should i thin the paint, an can you give me any tips on actually rolling the paint on.
I think you are supposed to thin about 10% with interlux but it will say on the back of the can. For applying: go look on youtube for roll and tip. It involves leveling out the paint by lightly passing over the freshly rolled paint with a fine quality foam or natural brush. Works really well for these applications. Also: I would try not to work the paint too much, if you work it dry it will cause texture and orangepeel. Try to keep your coats fairly wet but experiment with wetness to see what causes runs!
