Found this thread through the latest Hot Rod magazine. Can't wait to roll satin black on my '65 Fairlane. Is wet sanding recommended between coats with the satin? I know that info is probably here somewhere but I couldn't find it. Steve C., were we neighbors once upon a time? Check my profile.
gfeighny is the member that did the satin on his 69 'stang. He said this in a previoous post:
"No, I did not wet sand, Just layed down 2 thin coats. In places where I had roller marks, I just kept going back over it until the marks blended out. I used the low odor mineral spirits which dry alot slower so you can re-work the whole car for like 15 minutes, using medium-thin paint.
As an aside, I have touched up a few spots on the edges with spray can satin and it blends right in with the rolled satin. "
Not sure if we were neighbors, although I used to live on Corunna Rd near Seymore - just south of Flushing (that was about 15 years ago).
