Its not white paint but I had pretty good luck with rustoleum "hammered" wheel paint in a spray can. My bmw came with 3 hub caps and the steelies looked horribly rusty and full of brake dusty. The main step that most people seem to miss is sanding and cleaning the wheel down to where you have a good surface for the paint to adhere to. Masking off the tire and stem was a little time consuming but well worth it.
