noted.
i should be wet sanding with 400 correct. not dry sanding?
i already primered all the parts where i went to metal. ill wet sand them to insure theyre ready to go.
How uniform is the current finish now?
If you have sections of varying colors(example; red paint, grey primer) it may show through even after several coats. In extreme cases, it's worthwhile to prime the entire car.
