If I wetsand will these specs go away?
Yes, that's part of the reason you are sanding between coats. Knock down the dust specks, the orange peel, stray bugs, etc... before you proceed to the next coat. Attempts to bury them will likely just make them bigger.
In addition to the excellent advice of DonnyO, make sure _you_ are clean too. If you've been doing prep work prior to painting, dust can fall out of your hair or off your clothes and end up in the paint.
Clean the work area, clean yourself, clean the surface you are going to paint. And, while tack rags will make your hand sticky, they do a good job of picking up dust, so use them.
