entity, Thanks for that, really helped...I plan on picking up a squeegge now.
But I have a question, I just rolled my first layer of Gloss White Tremclad and I ran into a problem
I didnt do enough research here and I kind of just rolled paint on the car and kinda wanted to see what would happen...Everything looks good except that i have a few runs that you can see on the doors, but you can't feel the runs, its really smooth..Do I have to sand it down or can I go ahead and roll my 2nd coat then sand.
I tried sanding with 600 grit, but i found it really hard, its very sticky because of the paint.. even with water..But maybe iam using the wrong sand paper so tommorow i'll go buy some 3M
also another question, do i have to wipe the car down with Mineral Spirits every time i am going to paint? or was that just for the first coat
