If you spray instead of roll do you still put on very light coats or just use the paint and mix according to can. Like normal "automotive paint." I am think about using the brightside primer and paint. Spraying interior, door jambs, engine bay,and other hard places. Then Rolling exterior body.
That's basically what I did, I shot the interior and behind the truck cab between the bed and cab area. I mixed the paint for spray.
