i guess i will update you guys again since the truck is half way back together.
Ill update another time once the truck is all together, and again when the paint is buffed.
As it sits now
notice how everything is very straight except the bed. I am going to completely re-do the body work on the bed in a few months.
I've seen a few 2 tone paint schemes in this thread over the years but I'm still curious when another one is posted how the poster did this.
1971Ford, did you paint one color for several layers with a taped line and then move the tape and switch to the other color? I would think tape would be required to get a decent line. Obviously you are putting trim over the area where the colors meet so the line quality doesn't have to be great.
Do you wetsand both colors at the same time?
Do you mask off the lower portion when painting the top or was the top completed before the bottom was even started?
I guess an explaination of what you did would be better than me asking a million separate questions.
1970 Dodge d100/eventually going on a 77 D100 frame
