marq,
after how many days you suggest to polish the paint to remove the dust pieces?
I'm almost ready with the final coat on the passengerside...
Well... I am confused.... with the sequence you just described above. I would not be 'polishing' to remove dust and then following it up with a 'final coat'.
IF you are planning to add one final coat of paint... I would be only doing a very high grit wetsanding to prepared the surface ( and nail the dust at the same time ).
no, sorry for the confusing..
The car is now ready, all the paint is on the car.
Now there is some dust on the car on the top paint... Not very much, but it's good visible..
So I think polishing is the best way to do I think.
What do you think? and when can I do this?
How long must the paint harden
