I have a question about what you guys are talking about. Once you wet sand the final coat, and you're left with a dull finish, is the final "shine" really the result of the polishes that you buff the car with? Once you wet sand topside and one you wet sand rustoleum , they're both dull right. So is the polished topside still shinier than the polished rustoleum, or are you guys suggesting that the un-wetsanded topside is a lot glossier than the un-westanded rustoleum.(which i know that must be the case) I'm just curious how much the polishes play a roll in the finished outcome when comparing the two different paints.
