ok I just got done reading a bunch of the first thread, noticed there was a huge 2nd thread, and even a 3rd and gave up. I would like to try this method this weekend and would like to know if I am missing any steps at all.
1)sand with 80,100,200,400 (use a foam/rubber sanding block)
2)paint two coats and wait 12 hours, paint another coat (paint with rustoleum aklyd enamel mixed with mineral spirits so it is almost like water)
3)sand with 600
4)
5)sand with 800
6)paint two coats and wait 12 hours, paint another coat
7)sand with 1000,then 1500
8)polish with the cheapest turtle wax compound and buffer
*keep sand paper wet with a spray bottle when wet sanding and use a shammy to wipe off extra water.
I've searched a lot for some sort of step by step just so I could print something off to have and not have to remember it all in my head. Did I miss it somewhere?
just found a good guide. It's about using the brightside but the process seems the same. If anyone want's the link, here it is.
http://carpainting.wetpaint.com/page/Rollering+Interlux+Brightside+Polyurethane+Paint/diff/9,10?t=anon
