I prep the surface by using a leather shammy (sp?)to soak up the morning dew, then finish with a paper towel. then after it dries, i go ahead and give a final wipe down using a tack cloth. apply paint and the surface is kind of grainy.
you didn't mention it is your list here but after you get the surface dry you should be wiping it down with a cloth damp with mineral spirits to clean it, then let it dry for a few, then go over it with a tack cloth. cant forget the MS wipe down!!
