Yeah dude, you'll do ok. You're traveling a path others have tread before. (So read those threads! They're a TIME saver.)
The final coat was 5% mineral spirits, 30% FRESH Penetrol, and the temperature was around 50 degrees at the time. The main thing is to follow Charger's, Exit's and Marq's painting techniques.
