I sanded through the edges on my first 2-3 sessions before I realized I needed to do something different. Taping the edges off each time I wetsanded helped me a bunch on my practice panel. It kept me from accidentally knocking the paint off in these areas with the coarser rounds of sanding. Toward the end of each session, I pulled the tape off and touched the edges up carefully, using the finest grit possible.
This technique will also prove useful in your final polishing.
