Mx2001 - your adhesion issues are not from mineral spirits being on the surface. You problem is you did'nt prep the original paint correctly, IT'S STILL SHINY!!!!! you should have completely sanded the original paint and prepped with 400 UNTIL THERE WAS NO SHINE IN THE PAINT>>>>> THERE"S YOUR PROBLEM!!
Also wipe it down with a good grease/wax remover before you sand.
This will work just be patienct
