where the hell would I get 2000 grit paper...I have some 1000.....and do you really think that will work? I am just about ready to F it and spray the damn thing.
I think i picked mine up at autozone....bout 1000, 1500, and 2000. but what i think the real problem is that the polisher you are using is not powerful enough. i had the same problem. so I jsut thinned the last coat very thin and left it like that with no sanding or polishing....until I get(can afford) a good polisher!!
I'm thinking its both: final sand and crappy buffer. 600 grit for the final sand is not even close. You gotta get to at least the 1000 grit wet sand stage before you try and polish.
And NO - 24 hours is not long enough to wait before you polish.
And - most people do not get good results with the cheapo $30 buffer. There have been a few exceptions, but not very many.
