my goal is to put it on smooth enough to not have to sand at all.
It is possible to lay it out smooth enough with just a foam brush that the final sanding and polishing step is optional. I've seen
this car in person, and I had to look really hard to find any brush marks. Black will be less forgiving, but I'm sure you can get good results with a minumum of sanding and polishing.
