To add a picture you can attach it to your post. Just make sure that the "I want to preview my post and/or attach a file" box is checked and then when you submit the next page will show a preview of your message and there will be a "browse" button that you can click to search for the image you want to attach. If your image is already on your PC just navigate to the directory that the image is stored at and click the [ok] button. If the image isn't on your computer yet- but on your camera- that will involve a few more steps. Mainly it would require you to connect your camera to the computer or take out the memory card and stick it in a card reader which you should connect to the computer- Either way you would navigate to the directory that the image is stored at and select it. If you give a deeper explination of why you can't seem to post the image here I am sure someone will have a good fix for you.
