Here's the professional can and the standard can. Just to be safe I think I'll go to lowes and buy 4-5 quarts just so I have it.
I know 69charger said he used under a gallon for his charger. i'm going to plan on screwing up a few times, so I would buy at least a gallons worth + a quart for an old mopar.
jagd, you might want to wait a while to see if it hardens up for you, then if not consider putting 2 more coats like you said, after wetsanding with 800 or so.
