Quote: Last attempt to maybe get a answer on if there is a rollable primer . I just want it uniform color. is there a rollable primer that i can use? and how can i thin it? Thanks
White paint. Two or three coats.
White pigment gives the best, most solid cover and should give you a solid base.
