Goody - if you are wetsanding with a block, I would be surprised if you don't see the "peel" still showing after you think you are done sanding. As much peel as is showing in the photo, you should see it.
Definitely bite the bullet and go to a more coarse grit, and sand it till its flat - you really should see it when its there.
