I don't think it really matters exactly how much thinner is used, but it does matter how thin the end product comes out. If it's warmer outside, obviously the warm paint will be not so thick and won't require as much thinner to achieve the proper thickness. It's really based on ambient temperature so you can't just lay down a specific mix.
