I used the 7747 Yellow on a Duster fender...was going well till I screwed it up by doing the two coats then wet sanding and then on the third coat leaving it outside on a foggy cold night...bad One thing I did play with however was using a combo of the roller and then doing the wheel lips with the same color in the Rustoleum spray...I wonder if you could use it to do jambs and hard to get too areas. I did notice the two blended fine.
Want to see true paint quality I could show you my Bee with the original paint on the inner wheel housings and inner door frame with all the nice drips and runs in it. these things were not exactly painted to some show quality out of the box anyway.
77 Macho Power Wagon LWB factory 440 70 Coronet 440 N code 3 speed
