Hi man, have you used the turtle wax polishing compound that was recommended? That should help get rid of most of the spider webbing but you need to take your time and not just do a once over. After that you probably wont have many noticable scratches. You could probably use a product specially designed to remove the swirls. There are some products that fill the very light scratches and make it look like they disapeared. I see spiderwebbing after color sanding with 2000gt .. but havent polished yet.
