a non member emailed me this:
Thank-you for contacting Rust-Oleum Consumer Brands Canada
The Rustoleum Stop Rust and the Tremclad are both about the same products, They are both Alkyd oil based products However the Stop Rust is not sold in Canada and the Tremclad is not sold in the United States.
You will not find the colour you are looking for in Canadian retailers.
If you have any other questions please contact us at 1-800-387-9879.
Regards,
Rust-Oleum Canada Technical Support"
Thanks again
~Steve
so i think EXIT1965 is using the same paint as i did. that should clear it all up rust fighter and stop rust are the same product, just labeled differently in different states. so use the stop rust/rust fighter if you want the equivelant paint that i used; tremclad
