The mineral spirits wouldn't do that, so it's the paint, try thinning it more. Get it close to water just to see if your bubble problem goes away. It shouldn't run as long as you run over it lightly after first application, and don't get caught up in trying to coat the area with the new color on the 1st, 2nd or 3rd application. It's easy to lay the 1st coat on too thick because you want to change the color of whatever you're painting, but really your goal should be just getting a smooth thin layer of the mixture on.
That sounds like what i needed to hear. I think my paint is too thick As soon as i can get it runnin and in the garage. its gettin painted...er i mean roller
Heres a photoshop of what it should look like. Color may be a little darker when it comes out
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
