I need help :S, i dont think i'm doing it right. First two coats i got alot of bubbles and now that its dry it doesnt look too bad. BUt i just started wetsanding and boy its turning out DISGUSTING! Paint is thinning and i can see the original red/body. I'm slightly wetting the 600grit sandpaper and well with not too much pressure with a block, in a circular motion sanding it. Its coming smooth but it has like small circles (Not holes but like white circles) all over the body which other wise shines up when i whipe it with a mineral-spirited rag. Now i have spots on the car where the paint wasnt thick enough back to its original color which was the sanded down red of the buddha civic.
Should i keep going with the wetsanding cuz i only did the driver side.
HERE are some pics, HELP! I'm also considering just painting the car white cuz i have a large gallon of the professional white color. ARGHHH this is aggrivating.
