That random orbital buffer will not cut paint anywhere near enough to buff out sanding haze. It has very low pad speed and a very large contact area. That is designed for people who have never used a buffer before because it makes it impossible for you to burn the paint. If you have a buffer that will not burn the paint when used improperly, it really isn't doing anything. You need a real 7" rotory buffer with a wool pad.
2003 Mercury Marauder, 34k miles, 3.73s and custom flash tuned
1981 Camaro, 350 w/ Holley Stealth Ram MPEFI, Sportsman heads, roller cam, self-burned chips, wideband O2
1983 Firebird TA
1993 Saturn SL2 83k
