good work rick, i have only tried mineral spirits, and i've never had issues with bubbles staying and ruining the paint, so i'll stick with the mineral spirits, i have sprayed this paint and it sprays espically nice and much eaiser than any other paint i've ever sprayed. if i had the room i would have sprayed the charger, but the damm thing is too big to fit in the garage!!!!.
exit - definetly the alluminum stuff is really wierd paint, it was fine in the spray can form, but i did notice it acted really funny, not at all like the tremclad paint, i only used it on the wheels of the VW beetles, and it holds up really well but fish-eyed like mad.
one more thing about spraying this paint, it does'nt stink nearly as bad as single stage, and you can get away with alot lower pressure, and it does'nt suspend it's self like single stage paint does, meaning that your garage will not be totally smoked out after 2 mins of spraying.
