I've been observing this thread for some time now, and thought I might add a suggestion in regards to the problem w/ bubbles. It has been mentioned several times that the "thinner" the paint the better. Would this thinned-down paint be thin enough to pass through one of those cheapy paper 'strainers' that they hand out at the automotive paint stores? If the paint mixture was thin enough, could this not remove most if not all of the bubbles from having the paint mixed?
