harrisonTX - way to heavy a coat, try thinner coats, less mineral spirits, mix the paint alot more. you should see the body work thru the coat of paint until about the 3rd coat. oh and those little bubbles in the paint hint that the paint has been thinned a tad too much, they can be made to go away it you wait about 5 mins after painting, then just barely any pressure running the roller over it. then wait a few mins and the bubbles are totally gone. if you see those bubbles in the paint pan, then get rid of them with some paper towels and just "skim" the surface. but u definetly have to use thinner coats, less mineral spirits.
