I'm using Rustoleum Professional in Gloss White, with acetone as a thinner. I'm using Professional because that's what Walmart had onhand. So far, it's working well for me. But then, I'm easy to please!
The problems so far are mostly in my roller technique. Practice is making me better at getting the paint on without creating more work later.
Advil helps with the sanding!
The car (1964 Valiant four-door) has worn badly faded white paint, grey primer, and surface rust for years. I drove it to work and back, worked on mechanical issues, and let the finish slide.
