He said not to get the paint shaken or you would get bubbles. Did you get it shaken? And he also said that after you down a coat, to let it sit for a minute, then go over it lightly with the weight of the roller only. Did you do that?
Otherwise maybe 69Charger can help you out.
I didnt have mine shaken, and i went back over it with a roller and still had a couple bubbles. It was the first coat, so maybe after the next coat that wont happen
oh and i just bought some Smoke Gray rustoleum that im trying out. The paint was a litte thicker than it shoulda been im sure, turned out ok. The next coat will be thinner and it should look better. So normally there is no sanding between the 1st and 2nd coats right? just 2nd and 3rd? I'm using my trunklid for testing
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
