Can you look at the list of ingredients on your tremclad can and post them in order. This tells which ingredients have higher concentrations. Anyhow if it has mineral spirits as a key ingredient I do not see how it would not work when thinning. I may try to buy a small can and try it. Also thinking about using the hardner thats available with the valspar and only using half of what the normal ratio of hardner is.
