On the "professional" rustoleum test area, just today I noticed that in one small area, the paint appears to be doing something very strange. Here is a picture. It's bubbling up or something here, and it super easy to scrape off. Any ideas what may be going on?
The "standard" rustoleum area can be seen in the 2nd picture, and it still looks good besides all the scratches I've put in it with various things, but mostly my fingernail. The final coat was applied 3 weeks ago to the day, and I can still scratch it easily. Either it will do something magical in the last week, or perhaps it will take a bit longer. I really hope it gets harder than it is. The weather has been cool and wet which I'm sure doesn't help.
Unless I can figure out the problem with the professional side (nothing is coming to mind..) I'll probably go with the standard, if it dries and hardens adequately.
I think the problem with the Standard is not hardening but rather it just doesnt stick to bare metal. I have done the scratch test after 4 months and it would still scratch off. Maybe if I had used primer it would have stuck better, but the point of this excersise is not to use primer!! The Professional is a different story, although I think both the stickiness and hardening properties of Tremclad are better.
