After a few days off, I started up again today. Wetsanded down coat #4 with 400 grit again, mostly because it was a bit messy. I found that the areas that cause me the most trouble are around the attachments (fridge badging, handles) which I taped off. the paint just wants to run no matter what I try. Granted, if I were painting a car I would remove all of the, but for the life of me I couldn't figure out how to get the fridge doorhandles off without tearing the doors all apart and I was not interested in doing that - all the beer would get warm!
After some sanding down, I went with coat #5 before I ran out of paint. Here are the results after about an hours worth of drying time. It's dry enough for another coat, which I'm fixin to do after posting these images.
