Bakuryu - if you think of it, take a close up photo of the bubbles. It's kinda hard to tell from the daytime shots whether it's bubbles or something else stuck to the paint. Otherwise, I think it's coming along nicely. Be forewarned before you get to the final stage though... when you do the final wetsanding, use the finest grade paper you can find, like 2000, to get the surface as smooth as possible before you begin buffing it out. The buffing process is gonna take lots of time, LOTS of time if you're using an ordinary cheapo orbital waxer/buffer. It does work, but it's gonna make the paint process feel like it was absolutely rapid fire in comparison.
