Quote: Hey 'Charger! Very interesting animal you let loose here! I ought to try this on my ride once the weather improves. Question: You think this would work on refinishing aluminum wheels? Any change in procedures you'd recommend?
I'd be careful with aluminum wheels as aluminum has different bonding properties. If you're gonna paint right on the aluminum use a zinc chromate primer (made to prime aluminum specifically)
