Quote: i finaly got a good coat of paint on one side of the hood i'm painting, thin that paint out boys just like water then go over it after about 5 min with the roller again. i'm buying a spray gun because if the paint is that thin it would probably be a pain to do the sides of a car and if you get one coat with orange peel and don't sand it back smooth you just keep getting the peel look.
If you're going to spray, why not jump up to a cheap single stage. I figured the main advantage to this was you could apply it with a roller, no overspray, etc.
