For those not sure about this, it is not too different than the original way that cars were painted. Back in the day, Ford, Chevy etc painted their model "T's" etc with crews using brushes. Spray painting had yet to be developed. The same process, brush on level, sand and repeat was was used.
I do share the voiced concern that these paints will fade and/or yellow over tiem if exposed to much sun/UV. This can be mediated some by using a clear coat.
Good luck to those adventurous. Maybe if I paint my Camaro I'd try it!
