Hello
I just wanted to share the results from my initial experiment with 69chargers method. I used Brightside to paint the hood of my Fiat 124 Spider. I'm currently in the process of converting it to an electric car and I'm on a tight budget so a big thanks to 69charger for showing us this great method.
I blended my own color using white and yellow brightside, the ratio is 4 parts yellow and 3 parts white.
Here's some pictures of my result.
As you can see I used 3M rubbing compound and polish/wax. It worked really well and fast. I didn't have to spend a whole lot of time rubbing.
Overall I'm happy with the end result and will proceed with the rest of the car.
More pictures as well as a detailed writeup can be found on my website.
www.electric-lemon.com
-Peter
